65SportFuryGuy
Good Morning gentlemen. I got a little time Saturday afternoon to try and start the engine. Hooked up my remote starter and sprayed starter fluid in the carburetor and hit the remote. Let the engine turn over for about 30 seconds. Filled the glass fuel filter with gas but the engine didn't fire off . I didn't have time to see if I was getting fire from the coil. I usually pull the #1 plug, plug it back into the spark plug wire with a alligator clip attached to a piece of wire. I clip that to the thread part of the plug and clip the other end to a common ground, use my remote starter and watch for a spark for about 30 to 45 seconds.
After reading Big_John's reply. I really do need to check the gas flow with the plastic coke bottle. As to why I didn't do that right off I don't know. I have done that in the pass. I'm also going to check the coil direct using Big_John's way. He's checking the coil direct where I'm going from the coil through the distributor, to the plug wire, to the plug. In other words I'm going around the world to check the coil when I can do that direct.
Well guys I won't get a chance to work on the problem again til after Thanksgiving. I hope all of you have a great and Happy Thanksgiving Holiday.
on to electric checks.
