New to me 69 300 CM27
AL_Brad
Pell City, AL
Greetings all,
Purchased a 69 300 Convertible from NC. Not my first fuselage Mopar, but my first convertible. Needs this and that, but it's drivable. Nicely optioned. It does have cruise control but the online VIN decoder didn't list it - maybe out on that tag he didn't get in the shot. I look forward to reviewing the threads here.
CodeDescription
E85440-4 Barrel
D32H-D A-727 TorqueFlite Trans / Some Years A-998
CM27C = Chrysler
M = Medium
27 = Convertible
K9CK = Unknown
9 = 1969
C = Jefferson Avenue, MI, USA
184264Sequence Number '184264'
L1Paint Code: Unknown At This Time
L1Trim Grade/Style/Color
L = Low
1 = Cloth and Vinyl Bench
= Unknown
M6WUpper Door Frame: Unknown At This Time
W1
C04Order Number: C04
H51Roof Type OR Color: Single Air /w Heater
R37AM / FM / Stereo / 8 - Track
R31Duel Rear Speaker w/ R85
P31Power Windows
P41Power Door Locks
P45Power Deck Lid Release
G21Clear Glass / AC All Windows
P28Power Seats Left and Right
B41Front Disc Brakes Some Yrs. Power
C13Front Shoulder Belts
V7WAccent Stripes - White
L31Hood / Fender Mount Turn Signal
L35Corning Lamps
Gotta love those on line decoders.....
K= 440-4bbl 350 horse.
L1= exterior color = Sandlewood. The Jefferson plant coded the paint twice regardless if the car was a convertible or not.
M6W = interior trim = medium level of trim; bucket seats; black and white interior
W1 = inner upper door trim is white
C04 = Scheduled production day = December (C) 4th (04). May or, likely, not be the actual production day.
H51 = a/c
C21 = fold down arm rest "buddy seat"
G11 = tinted glass - all windows
Neat car!
Where are the factory rear speakers on a convertible? There should be three working speakers for the front speakers, on the upper section of the instrument panel.
Just curious,
H51 = a/c
Nice. Thanks. That makes more sense.
Neat car!
Just curious,
I'll have to look when it gets here..
The "R31" is rear speaker, not dual rear speakers.
Speaker is behind the grille on the rear seat back.
Transport driver dropped off the car this morning. headlight doors don't go down when the lights are turned off, but the 8-track works. lol
PO put an Edelbrock 1406 on it. It looks to be brand new, but it should be a Holley for the 440 in 69 shouldn't it? Choke rod of course doesn't fit so not hooked up, and the washers and safety pin are missing from the throttle/trans kick down lever. Nothing but the tire in the trunk... where do people put stuff. Interior will need total new seat covers and throw a new carpet in with that. Definitely needs a new top.
BUT... new tires, battery, and I drove it into the garage.. so that's a start.
Check the bulbs. Believe it or not, if a bulb is burnt out, the doors won't close. The ground for the door relay comes through the bulb filament.
For the 350hp 440, yes, it takes a Holley. For the 375hp version, that takes a Carter AVS. With the "K" in your VIN, you have the 350hp engine.
No kidding... interesting. I'll check that. Thank you
One omitted item overlooked is the dimmer switch. Combine several bad connections and the doors won't close / poor operation.
I have the K, but someone before me changed the cam, carb to a Carter, and dual exhaust. I guess they sold it cause 4400 lbs doesn't make a good race car hahah.
