I've an ignition problem in my ´74 fury 360SB and I think is some kind of short.
Some days ago I replaced my aftermarket ignition and distributor with a mopar OEM ICU, and mopar OEM distributor by spectra premium and also used a brand new pertronix flamethrower coil and brand new ballast resistor.
My problem is when I put the ign key on "run" position even with the engine not running the coil turns REALLY hot very quick, even sometimes the carburetor's choke turns hot too and I can see a huge drag of current on my ammeter and also my battery gets discharged really quick
Also If I disconnect the battery, put the ign key on "run" position, put a spark tester in the ignition wires and then connect the battery I can see the spark tester fires one time.
This problem is intermittent but when is present I loose the spark while cranking (no spark even with the spark tester) so I don't have ignition
but when turn the key in the previous position of run (i think is ST) the spark tester fires one time but I don't have idea why is having this behavior
Any idea where should I start looking?
