Gerald Morris
I think you want to leave that in place so it powers the ECU, but I could be wrong.
The car is a '72, and the electronic ignition was a factory option that year, so I assume it's been rewired like the factory did. There's a screwy "back feed" (for want of a better term) that comes back through the ballast resistor to limit current and power the ECU.
I think it's safe to assume the coil and ECU is OK as the car will occasionally fire as the key is let off.
I'm thinking the fault is in the ignition switch, bulkhead connector or wiring. Since it's been rewired, that also brings in the quality of wire and connectors/crimps.
I suspect you're right. Yes, in retrospect she needs to feed current to the ECU from something, and that might be the only junction.
I had a merry time with getting a 4 wire ECU to work on my D150. It's ALMOST a "plug and play" setup, but I had to make a little bypass to the ignition using a NO relay with the starter loop. With that, the ignition gets full current when starting, and then the usual fraction once started. The fact that the starter relay on the '83 had contact points, but no actual circuiting for such suggests the processor board did that bit of switching. I still have it, as somebody might want to rebuild one.
