If your current pan has no steering relief, I con't see why a B-body center sump pan would not work. However, @Badvert65 is a slab side guy and can probably give a firm answer.Will a B body 383 pan (Charger, Coronet) fit a '66 Polara with a 383? They look the same (no steering relief) laying under the car.
Thanks in advance!
I believe that’s the one.It appears I need a "187" pan. Is that correct?
