Scott 440 TNT
My 68 300 needs a OPG, I don't see a sensor location.
Where can I connect the fitting for the oil line.
Where is the Pressure Sending Unit located.The oil pressure sending unit can be removed to install the gauge fitting or there is a second galley fitting opposite the pressure sending unit. Be sure if you bought an after market gauge that you discard the crappy plastic tubing in favor of copper tubing and save yourself a leak down the road..
Dave.
Doh. I bought the crappy plastic tubing, back to the store again.The oil pressure sending unit can be removed to install the gauge fitting or there is a second galley fitting opposite the pressure sending unit. Be sure if you bought an after market gauge that you discard the crappy plastic tubing in favor of copper tubing and save yourself a leak down the road..
Dave.
Oh, I know.. ask my 17 year old self what happened.. bad times...covered a fresh engine and fresh primered car in oil..Better yet, buy an electric gauge and not worry about running the line or having the line break. It's a mess when it does.
I almost hated to add a "like" to that, but yea, once you've done it, you know.Oh, I know.. ask my 17 year old self what happened.. bad times...covered a fresh engine and fresh primered car in oil..
True, I just had this gauge already in the stash.Better yet, buy an electric gauge and not worry about running the line or having the line break. It's a mess when it does.
Understood. But if that's the case, you don't really need to go to the trouble of running it inside to the dash.True, I just had this gauge already in the stash.
It's just a temporary install to get some data.
Just an under hood app for now, electronic dash gauge later.Understood. But if that's the case, you don't really need to go to the trouble of running it inside to the dash.
I look and see 0 psi! OHHH ****!
You can still run your original oil light and a gauge. There should be two ports back there. One with the original sender and one that is plugged.
