marty koirtyohann
i have always used a ac water pump (high flow ) with np & i raced it & driove it for almost 13 yrsThank you all for the suggestions! I really do appreciate the help!
The thermostat has been replaced, the filler pan/front valance is there and the lower hose is new with the spring in it. The radiator is a new all aluminum replacement that was supposedly sized for the car. It has a new cap with a temp gauge in it. When the gauge in the car says it's hot, so does the gauge on the cap. I've also installed a overflow reservoir to keep it from puking all over the place when I stop. I thought about trying a high flow water pump next. I'm pretty convinced that it's a water flow problem and not an air flow issue.
After reading cbarge's comment, I may pass on the high flow water pump.
the old direct connection racing book called for the ac water pump i believe them (old school guys) but let me know what u do to get it fixed . is it overheating driving down the road or jusy in town . i had the same problem toll i replaced the fan clutch . u c the clutch will turn more when its hot u need the one with a soring in the fount of the clutch
