bluefury361
Hey guys, I've got a problem... need to pick your brains...
The left rear window, (power), in my 69 300 will not operate. The motor is new and runs great when powered up on the bench but when connected into the harness will not run
Both gang switch and the single switch test good. the motor gets a signal when either switch is activated, but will not run, either way.
All the other windows work fine.
I have the schematic from the shop manual and have inspected the harness wiring and connections, all look good. multi meter shows 13.7 volts at the motor througn the harness.... still won't run.
Any ideas.....? I can't install my interior until I get past this issue.
Any help or suggustions will be apreciated.
Will
Will
