For Sale Putco wiring harness
75LandYacht
Yank Tank
Westchester NY
Up for your consideration is this Putco Wiring Harness I bought to use on my 77 NYB.. due to the harness messing with the operation of my headlight door, I chose to not use it. It was only install in the car for a few weeks before I removed it. (If you’re considering a harness to use on your car that has headlight doors, big John sells a relay to fix the problem. ) So it does have some overspray and dielectric grease on the plugs, but it works perfectly. I will say the headlights operated much better with the harness plugged in, but as mentioned the harness messed with the operations of the headlight doors.
I think the harness was 60 or $65.. I’ll take any reasonable offer plus you cover the ride..
