Ranger whhels on C body
Rustyrodknocker
Salem oregon
I'm pretty sure I have seen some Ford ranger wheels on a C body but Im not expert on what are actually Ranger wheels.. I may have just thought that's what they were. Either way I have a chance to grab some cheap mounted snow tires in great shape but they are off a Ranger.
This is for a car in paid storage so I want good tires that don't go flat. Can anyone confirm these bolt up?
Check the center hole diameter as Ford tended to have some which were a hair smaller than what Chrysler used. I've read of people having to put the wheels in a lathe to slightly enlarge the hole in the old '80s Ford OEM "wire mags" to use on mid-70s Chrysler products.
FWIW,
I also think the center hole is going to be too small. This is assuming '83-'11 Ranger.
https://www.therangerstation.com/tech/ford-ranger-wheel-fitment-guide/#gsc.tab=0
70.5mm = 2.77"
IIRC, Mopar center is 2 13/16 or 2.812
So, if you don't care about the wheels, a couple minutes with a die grinder would open up the center.
FWIW,
Thank you for saying "some." When I put these Shelby Cal 500s on my Newport, I had guys on C Body sites telling me my wheels were going to fall off. It was only a mater of time.
Had them on for 12 years and over 40,000 miles.
I will say, I'm referring to STEEL fomoco wheels. Aluminum rims are not the same aluminum fomoco have a larger hub center.
Im thinking that the cars in the back of my mind that had ranger wheels probably actually had jeep wheels.
I passed on the ranger wheels. Im not interested in doing the work to modify them. Negates the easy button.
