How do I do this on this particular vehicle? Step by step would be great.
Nick
Nick
Doesn't the horn button rotate off? Grab the wheel and twist the button off like it was a jar cap.
you have a bad turn signal switch/cam inside you will need a new one.Hi there. I'm trying to do the same thing with my 66 Monaco 500 hardtop. Not sure on how to get the horn ring etc off and don't want to bust it. I'm in NZ and Monaco parts aren't exactly thick on the ground here !!
My right hand rear stop and indicator lights have stopped working and have tracked the problem back to the column. Also as my indicators have stopped self cancelling, I thought I'd fix both problems at the same time. Any help would be much appreciated.:sSig_thanks:
Yep. Thats what I've worked out. Once I can get the horn ring/centre button off (all one piece) I can order a new part off e-bay, unless there are any better solutions?
Thanks Alan. My post wasn't very clear. I also didn't realise that the button was separate. Button and ring are now off. As to the new part, I was referring to the turn signal switch and cam. I assume that the horn contact switch is part of this. If not, no problem as the horn works fine, it's just the turn signal switch that appears to be faulty. Thanks again
John
