Scarebird Disc Conversion Parts List
bnz84
Maryland
I collected some of this info awhile (3years) ago when I did mine and its about time I finish it and post it. I updated some of the links cuz some stuff has been discontinued. My 69 fury was originally a power drum car so no need for pedal changes and I didn't even need a proportioning valve. All totaled, with booster and master, about $650-$700.
Scarebird c-body write up. Old but accurate except my parts list was different than this one.
http://www.herrickenterprises.com/70duster440/public/ScarebirdConversion.pdf
Scarebird Adapters and hardware. $175
1963-72 Plymouth, Dodge, Chrysler "C" body with 4-1/2" bolt pattern front disc
Rotors (x2) - RAYBESTOS 6014R $90 total
https://www.rockauto.com/en/moreinfo.php?pk=1043019&cc=1498231&jsn=577
Booster and MC - A-1 CARDONE 503600 Reman. Vacuum Power Brake Booster w/Master Cylinder $130
I got mine from RockAuto but they don’t have it anymore so try - from advance auto
Booster alone - A-1 CARDONE 54-73309 $130
Duralast Reman Brake Power Booster 54-73309
Dust Cap (1 box) - DORMAN 618101 $7 (makes u buy 5)
https://www.rockauto.com/en/moreinfo.php?pk=12527&cc=1498231&jsn=5&jsn=5
**they did not fit perfectly so with some pliers bent the edges in just a bit and then they would hammer in.
Inner bearings (x2) - TIMKEN SET6 $10
https://www.rockauto.com/en/moreinfo.php?pk=1119632&cc=1440933&jsn=2
Outer bearings (x2) - TIMKEN SET2 $8
https://www.rockauto.com/en/moreinfo.php?pk=1116634&cc=1440933&jsn=3
Inner grease seal (x2) - TIMKEN 6815 $5
https://www.rockauto.com/en/moreinfo.php?pk=1119427&cc=1498231&jsn=4&jsn=4
Brake hoses. I got these and had to grind off the mounting bracket. Seems weird asnd I thought I did something wrong but I was dead set on the long 17" ones. I’m sure you could find a caddy hose with right length without the mounting bracket. The ones below do not show up in the RA list for the Caddy, but they are compatible.
Brake hose left - DORMAN H98914 $7
https://www.rockauto.com/en/moreinfo.php?pk=968680&cc=1026111&jsn=12
Brake Hose right - DORMAN H98913 $7
https://www.rockauto.com/en/moreinfo.php?pk=968059&cc=1026111&jsn=13
Rear RH lugs - WAGNER BD61235 $5 **with new RHT rotors the only LHT wheel would be drivers rear. I didn’t want that.
https://www.rockauto.com/en/moreinfo.php?pk=145904&cc=1232402&jsn=9
Calipers, the ones I got are below but they are discontinued. Pick what you want from this list. Since you likely will not have a core assume $140 for both if you choose pre-loaded.
https://www.rockauto.com/en/catalog....9l+v8,1354148,brake+&+wheel+hub,caliper,1704
Caliper right/passenger -
WAGNER TQM25003 Discontinued!!!
https://www.rockauto.com/en/moreinfo.php?pk=1259030&cc=1354148&jsn=2
Caliper left/driver - WAGNER TQM25002 Discontinued!!!
https://www.rockauto.com/en/moreinfo.php?pk=1255005&cc=1354148&jsn=3
***and by the way since these calipers are from a RAM 1500 I looked on ram forums to see what they are doing to improve braking. One of the obvious answers was to use calipers from RAM 2500. So I bought these first. They were slightly too big to fit into the Scarebird adapter. I think with grinding they would have worked fine. But I wimped out.
Speed Bleeders - DORMAN 12702 $7 *not required
https://www.rockauto.com/en/moreinfo.php?pk=452835&jsn=1
Bracket $175
Booster & MC $130
Calipers $140
Rotors $90
Bearings and seals $23
Dust cap $7
Hoses $14
RH lugs $5
Speed Bleeders $7
Shipping???? $60??
Total - $651
In case its not obvious those are just the parts I chose and worked for me. There are plenty of other options that will work. Some cheaper, some more expensive. I think you can get drilled/slotted rotors, painted calipers, etc. I was looking for calipers on craigslist or pic-a-part to save $$ and shipping $$. Even for a crappy core. The Scarebird list really just gives you applications, not specific part numbers. That is why I chose Rock Auto first because of how reliable the application-to-part correctness is. Prices are good too but shipping can get expensive and because of that searching other sites for the same part number you found in RA can be cheaper.
Oh yeah, stopping power is great. Of course I'm comparing to my system where the only thing that was working were the front drums. Back lines were rusted shut...with no leaks.
Thanks for that posting! When I first discovered the Scarebird conversions, I though it was neat as it was all sourced from salvage yards or the local auto supplies, rather than being from aftermarket vendors who might not be there years later. But as most of these vendors now have some staying-in-business "power", they might deserve consideration, too, as the older OEM replacement parts are now becoming more scarce. Still, for many people, the Scarebird approach has merit.
I always like OEM-level approaches rather than an "adapted" aftermarket approach, in general. BTAIM.
