- Joined
- Nov 14, 2010
- Messages
- 28,542
- Reaction score
- 28,385
I have had a worsening raw fuel smell from the engine room in the LHS so I finally made some time to handle it. I'm pretty sure the leak was from old worn out injector o rings but as long as I had it this far apart I thought it best to replace the lower intake gasket as well. There's actually a pretty good forum that I've been lurking on for tech advice and that's where the advise came from to do the lower gasket as it regularly dries out and causes performance issues. This car was having some of those too along with the leak. After acquiring an fsm for the car from Ebay I figured I'd be armed and ready for the project. I think the repair will go smoothly aside from this...one of the intake bolts snapped as I applied pressure on it, in fact it almost happened twice. Two of the bolts extend into cooling passages and breakage isn't uncommon. How would you guys/gal(s) suggest getting the rest of this bolt out of the aluminum head? Been soaking it with PB Blaster, hitting the surrounding area with torch and tapping on it hoping to brake the bond since yesterday and it's still not budging.
