1966-300
OK back again for free advice. After I rebuilt my 383 and got all the bugs worked out she is running really good with one small exception. When I really jump on it and accelerate moderately hard there is a ping/knock. I backed off the timimg to the 10-11 degree range and it mostly went away but still an occasional knock/ping especially after it is really warmed up. A friend has suggested rejetting the carb, suggesting more fuel for the .30 over cylinders. The rebuild was not a performance build, just a slightly bigger cam, and bored .30 over. The compression is likely in the 10-1 range maybe a little higher. What is the opinion of rejetting the carb? Currently it is a standard Carter AFB with the stock jets. I am dubious that this will have any effect on the pinging situation, and believe it to be entirely timing. I am going to try to post some pictures but have had no luck so far as they are all really big files and unable to upload. Any way let me know your thougts on the rejet?
