max1196
Can you measure or judge how much clearance you have?
Yes, the stock air cleaner should fit with the RPM (height wise), but it really depends on the carb you choose. Be careful when you order your carb so you don't get the wrong bore.Will the Eddy RPM let me keep my stock air cleaner?
Using the nearly new Eddy 750 off of the 383.Yes, the stock air cleaner should fit with the RPM (height wise), but it really depends on the carb you choose. Be careful when you order your carb so you don't get the wrong bore.
Then it will be fine.Using the nearly new Eddy 750 off of the 383.
Ok I'll bite, why?Cost of a roller cam and lifters makes no sense in the motor you are building.
$750 to $1k for the cam and lifters plus the following.
Distributor Drive Gear/Shaft for roller cam.
Cam Button on the inside of the timing cover.
Custom length push rods.
Head work or purchase of new heads to take advantage of the lift the roller cam offers.
Upgrade ignition to take advantage of new cam and heads.
ETC......
Cost far outweighs what you are going to be using the engine for, and if you are building a race motor you are not going to put it in a C body.
I'm debating also the merits of a roller cam with hydraulic lifters. Wondering if the can get a roller cam that will equal the specs of the 375hp cam that has been talked about here already.
Umm...if you are building a race motor you are not going to put it in a C body.
1. Edelbrock Performer dual-plane lo-rise.Now,
1. what intake manifold do I buy, and
2. where can I get a new electronic dizzy
3. with a non aggressive advance rate?
Dammit I wanted a documented 383 stroker build, oh well. I think you made right decision fwiw.
View attachment 107586 Coming soon to a Chrylser near me! What color should a '68 440 be? And, thinking I should have the tranny gone through.
How much HP do stickers give...;-)Well. . . That pie tin is worth at least 10-15 more horsepower!
