Fireguyfire
So I finally got everything ready today to do an initial run on my 440 in my 70 300 after I had pulled it this winter, and went through the engine and repainted it and my engine bay.
I’ve mentioned in previous threads that the previous owner had installed a generic painless wiring harness in the car, and although it ran the wiring was completely screwed up.
I tested and reinstalled the factory wiring harnesses this winter, as well as the factory steering column and wheel; the previous owner had installed a tilt column out of a later C body.
Anyways, upon start up today, the engine is firing immediately, but then quitting right away. I thought perhaps it might be timing so I played with that, and couldn’t get it to run. After starting it many times I came to realize that what I think is going on is that when I turn the key to start, the car fires right up, but as soon as the car fires and I turn the key to the run position it dies. I experimented with it and left the key in the start position a bit longer and the car will run nicely, until I turn it back to the “run” position which seems to kill it.
I’m going to start troubleshooting the problem, but I thought I would ask if anyone can suggest 1) a way to confirm that turning the key from start to the run position is killing the engine, and 2) suggest a logical way to go about finding what the issue is.
I’m assuming that with the key in the “run” position I should be able to confirm power, I’m just not 100% sure where the best place would be to check for power tge the key in “run”.
Any suggestions would be appreciated!
