ALLAN
I've got the steering out of my 1970 Polara and would like to replace the rubber couplings in the column, are they the same as B bodies? or breed specific? Also where from?
Thanks,been looking at some repair kits, looks like some conveyor belts could have 3"holesYes and first gen pickups if they are the flat ones. The replacement kits are a dime a dozed,
If you have a set of knuckle rubbers, you'll have to make them from a chunk of runner. A dremmel and a drill is needed. Time consuming but a positive solution. Been there
Well that worked The Land Rover coupling needed some fettling, nothing too drastic, replaced the seal on the Pot coupling using a new clip. nearly ruined my self lifting the new unit in but worth the effort.
