There is a bunch of threads on utube about this combo. I tried some of the extreme examples like bonding 2 pieces of aluminum at a 90 deg angle. Even bonding aluminum flashing on its end. It does work way better than u would think but cant take much torque. There are a ton of things other than this option - jb kwik weld comes to mind plus other epoxies which ive used for this same kind of thing. And certainly dissolved plastics like plastex seems perfect. I actually have some ...somewhere. But the simplicity and availability of this combo is tempting. When I do some dash panel work I'm going to do a neater job. Also going to try mixing a bit of powdered RIT dye into the BS. Evidently the CA glue doesn't solidify on it own because of added acid. If you neutralize the acid with a base it solidifies. It doesnt have to be powder that does the neutralizing. If I could slow the curing just a bit and add color that would nice. Anyway this is not a miracle cure for anything, just another option to put in your toolbelt. The stuff that makes the 18 year olds think your a wizard!
