lemondana
On my 71 Polara, the taillights quit working last fall. Brake lights and turn signals still work. I haven't had a chance to get into it yet, hopefully this weekend. Any ideas. Any help would be appreciated. Thanks!
I would start at the fuses but it is likely the headlight switch. Get a wiring diagram and trace back the wires. Could also be the bulkhead connection.If this were a ‘67 Imp I would blame the headlight switch.
The wiring for the rear of the car DOES NOT go through the bulkhead connector. It runs down the left side of the vehicle to the trunk under the carpeting.I would start at the fuses but it is likely the headlight switch. Get a wiring diagram and trace back the wires. Could also be the bulkhead connection.
Now that you mention it you are probably correct however that is the reason we use a wiring diagram. Sorry for misleading you a bit.The wiring for the rear of the car DOES NOT go through the bulkhead connector. It runs down the left side of the vehicle to the trunk under the carpeting.
