- Joined
- Nov 14, 2010
- Messages
- 27,945
- Reaction score
- 26,889
This is excellent, I just ordered the tool with the 5 seals.
Hi!MBar since it's been a couple years i was wondering if the new seal is still holding ? I replaced a leaking tail seal today and now it is time to replace the Shift shaft seal and the small Throttle lever seal. I have the seals all the tools you mentioned. The clearance seems tight in that area on my '66 Imp. I may lower the trans a little. My Driveshaft is in the shop so this is my Opportunity to Finally get this leak fixed, Thanks for your Guidance.
Excellent! So out of curiosity I just went out to the toolbox and found the tool... Never did pull the old seal off the extractor!Well, I did the two seal replacement today,Not too bad. I used the Methods and tools as stated in the thread starter. I used a bungee cord to hold the flat piece of wood on the pan for the C clamp ! Thanks MBar for this thread and glad his leaked is fixed and mine too,hopefully. Now I just have to remove the old seal from the tool !LOL
Same thing.Hello, I am about to do the same replacement of that seal and happy that I got forwarded to this thread. Unfortunately the kit is mostly sold out but I found this. Just not sure about the quality because of the price. Maybe someone got the same..... Transmission seal tool shift shaft 727 904 mopar chrysler plymouth jeep puller
ALright then I am going to order it . Thanks JohnSame thing.
The shop I mentioned seams to be offline. No payment is possible, no impressum, no replies. Weird. Why are these kits sold out everywhere? Any ideas where to get one? Maybe somebody of you guys wants to get rid of one?
Ahh... I'm starting to think that we all need to start to just change that seal when the pan is off on the older cars as part of the procedure.Yes that’s my Problem too I don’t want to spend so much money when it’s just more time I need to invest instead . I did change the oil and filter already that’s the point . That’s why I found the leak while refilling and run it on stands . Never had so much oil in it before and I know why
Good thread and information. I made it a sticky.With help and encouragement from several members, I was able to replace the seal without dropping the pan. I had a trans fluid leak that created a puddle under the car. After cleaning and inspecting, I determined it was the shift lever seal.. I ordered the seal and tool kit but was dreading doing this. Fortunately, got it done and it wasn't so bad at all.
Thank you to Dan Scully for the link to the parts.
Thank you to SAForwardLook for the invaluable tip to use a c-clamp.
I took photos along the way and I'm creating this post in hopes of helping the next guy.
I did this in the garage and with the car on stands as high as possible.
Here are the tools I used:
1/4 inch ratchet with small extensions and 7/16th socket
C-clamp
5/8 and 9/16 combo wrenches
Needle-nose pliers
Flat-head screwdriver
Small piece of plywood
Medium channel locks
Seal and tool set from eBay which includes extractor and installer
Brake cleaner and paper towels
Patience and about an hour or 2
Steve, this is where you and I are very different. I drive my cars (in good weather) like I stole them. I respect your choice and understand... But LOL... We're different there!I don't abuse my vehicles so I don't feel it is usually necessary to drop the valve body when I just change the filter itself - and I don't have to do that very often since my cars are not driven that much. But even just sitting, those seals will tend to leak over the years. I find using the tool as described in this thread is a real time/hassle saver and takes just a few minutes. Also, getting a pan gasket to seal well always seems to be a challenge despite the variety of gaskets I have used and making sure the pan is straight itself. I do not relish the mess associated with dropping the pan either.
I personally just use the tool and be done with it in just a few minutes.
I am surprised the price has jumped so much but it is a tool I use more often than most and to me the cost even at this point is well worth it. To each his own......................
I even did the part throttle conversion on a '65 Barracuda, which was a lot more involved of course, but well worth the effort.I guess we can agree John about the part throttle kickdown conversion aspect but I mostly own 1971 and up vehicles that have it as a standard feature and only two 1970 Chrysler 300s. So I have only had to modify two of mine so far and might do the same on my two Plymouth Sport Furys. I do have a 1969 Imperial coupe that the dealer brochure claims has the part throttle kickdown as an advance feature, but I will know for sure when I get the car running soon. I can put the feature in my 1970 SFGT if Carsten allows me to make that modification to original .
With over 20 cars, it is difficult to drive any of them regularly. I have mostly 1971 Chrysler 300s, New Yorkers and Imperials (obviously my favorites), then Dodges and couple Plymouths plus some Forward Look cars.
