- Joined
- Nov 14, 2010
- Messages
- 28,542
- Reaction score
- 28,386
NICE!!!
Wow, can’t wait to see it in July at Carlisle! But who will bring th parts car??
Haven't figured that out yet. . . Maybe you could come to Germantown and drive it up for me?
Wait... Are you actually going to drive something to Carlisle this year?But then who will drive my parts car?
There is a good possibility. My son will be back and I might have help getting it ready.Wait... Are you actually going to drive something to Carlisle this year?
Nice video, more impressive than I was expecting.
Those rusty clips hold the inside housing to the firewall. There are three removable connectors on the engine side of the firewall that all run horizontally across the housing. Squeeze the clips on the ends of the top one and wiggle it off so you can see the clips on the next one down, etc. The clips I'm mentioning are part and parcel of the black plastic connector itself.As some of you may know (from my postings in another thread regarding battery charging issues), I have had a problem trying to diagnose the cause of my no-charge problem. I have attempted to perform a couple of tests @Big_John and others have suggested. And being the spaz that I can be, I inadvertently allowed the hot batt lead at the alternator to go to ground. This caused a lot of smoke to occur in the firewall area where the starter relay and and voltage regulator are located. Looking at the photo below, I assume I have fried the fuse-able link (big blue wire) that runs from the starter relay to the bulkhead connector.
My questions: What is the best way to accomplish a repair of the fuse-able link? I assume I'll hafta disconnect the bulkhead connector and somehow disconnect the blue wire from it. I just can't figure out how to get the bulkhead connector to disconnect. There are four rusty metal clips (one at each corner of the connector), but pressing them or poking them, etc. has no effect. Is there a trick to this? Also, there is a black wire that I should also disconnect and replace that runs from from the fuse-able link to a connector that plugs into the voltage regulator, and again, I can't figure out how to get it loose from the plastic connector. Is there a special tool I should use for these connectors? Here is a photo of the whole mess:
Does this help? Fusible Link
Well. . . I finally repaired the fusible link and I resolved the no-charging issue (I went through two DOA alternators right outa the box). So I'm back where I started two months ago, and am now attempting to tune the engine, so I can put some break-in miles on it. I set the timing at 12 degrees BTDC (with the vacuum advance disconnected), and I diddled with the mixtures screws on the AFB, so as to get the highest RPM and best vacuum reading. The dwell meter says 23-24 degrees. The vacuum gauge indicated 20-22. In the garage, the engine runs fantastic: really good throttle response and pretty smooth idle at about 750 RPM.
When I got the car out on the road for a test run, however, the engine pinged a lot when accelerating, so I stopped the car several times and gradually retarded the timing; but I could never totally eliminate the pinging, and the timing was now so retarded, the engine ran like chit.
At this point, I'm not sure which direction I should take, but I strongly suspect my (rebuilt) distributor. I know the distributor in my Parts Car is in good shape, so I'm thinking I'll swap distributors next weekend to see if that has any positive effect.
What do you guys think?
What's the compression ratio? What octane fuel are you running?
CR is 10:1. I'm running 93 octane fuel.
