Tight rear windows
Jon Nagy
Rural Valley PA
I am looking for help on how you fix tight rear windows in two door vehicles. The smaller windows. WD40? Remove the door panel and tighten up the grips? Thank you!
Remove the rear seat bottom and the rear panels. Clean out any debris. The grease on the window tracks sometimes hardens over time so you may need to clean out the old grease and apply new grease to the window tracks. Make sure that the rollers/slides on the tracks are not broken. Good luck.
Thank you friend!!!
Don’t buy WD40, there are much better lubricants and penetrants sold.
