WANTED Turn Signal / Steering column shaft bearing housing
73Coupe
San Luis Obispo, CA
Looking for a turn signal housing. For 1973 Chrysler, probably same part for 71-73 P, D, C, Y carlines, with non-tilt column.
Cast zinc part just behind the steering wheel that houses the turn signal switch, hazard switch, ignition light, and upper steering shaft bearing.
p/n 3575230 or 3575231
I discovered mine to be cracked upon disassembly.
Thanks,
