Turn Signal Switch - 1965 Sport Fury
Mudeblue
Phoenix, AZ
Does someone know the Part Number for the Turn Signal Switch for 65 SF. Have ordered two of them and neither one is correct. Wiring scheme is different but has instructions but alas. Thanks.
There are probably different part numbers depending on which steering column and which features you have. I'm not sure about the 65 Fury, but for example, my 68 300 uses like 4 different ones depending on if it has the tilt/tele steering column, cornering lights, lane change, etc. Try to get the factory parts manual as it will explain all this. Sorry I can't be more help.
2631383 for non-tilt (A, B, and C bodies)
2496192 Tilt (C and Imperial)
I hope this helps
