I'm suspecting that any Poly "A" engine matched set from 1955 to 1965 might work? No real need to change them, although there might have been a few differences as time progressed? As to the seal on the dipstick (travel limiter of sorts) and minor things like that. IF you are not concerned about OEM correctness, but at this point in time, I suspect that FEW people would ever know the difference between a 1957 item and a 1965 item. Whatever you might end up with, be sure to verify the oil level on the stick for a "pan only" oil capacity, then "pan + oil filter" too.
Just some suspicions and thoughts,
