WANTED Wheel lug studs
Cowboyhenk
Netherlands
Looking for rearwheel lug studs passengerside for a 1956 Chrysler imperial. Anybody an idea where i can get those? Nothing on ebay, Kanter, Summit and others. They say books dont go that far back!!!!
Nothing at Andy Bernbaum or Dorman, gonna try to measure it up correct and try to find a matching one. Dont know if there is a difference in splines number?
It's going to have to be identical or it won't press in.
I'm really surprised Bernbaum doesn't have any.
I looked in the parts manual and the part number is 1633052 for the right and 1633053 for the left and it fits 56-58. I did a quick google search on both numbers and there wasn't much, but I discovered that that is also the correct number for a 63 Chrysler and Imperial. I looked in the 63 Chrysler parts manual to double check and the number is the same.
Rock Auto has Raybestos 27848B to fit a 63 Imperial.
This is assuming that the Rock Auto listing is correct for that application.
When you talked to Bernbaum and the others, did you give them the part number?
that year chryslers used a independent hub right ? would you like to replace the whole hub , if you need something that can't be had ? or you could re-drill the through holes for the next size knurl on a 1/2-20 stud , thats the fit for hubs that the studs spin in .
