LocuMob
Fluid Technician with a hat
Where can I put my temp sensor THROUGH the firewall in my 66 Polara? The hole that is below and to the side of the master cylinder isn't big enough without enlarging. Is there somewhere else that I might have missed? Is it possible to sneak it around my A/C hose outlets? Or too much of a PITA? Would like to know the temp, the car seems to be running a little hot. Nothing major, just gets a little warmer than I recall, of course I can hear it now with full exhaust this year.
Running a 440 with a .484 purple shaft, aftermarket aluminum water pump, Jeg's aluminum radiator (air does go over and under an inch each side, will be sealing that), electric fan pirated from a Bonneville (it was free after all), just put tti headers and full exhaust this year. Runs fine, slight pinging, the sound an engine makes when hot, not bad. Get it up to speed slowly and it's fine. Been turning on the fan for stopping and accelerating. Will be replacing thermostat just in case.
I run a lower ratio of coolant to water, if I had a cracked block from freezing, would it leak, and wouldn't it get hot very easily? I'm not thinking it's cracked, just wondering. I've had engines run completely out of coolant and that's not the case, plenty of light green stuff in the radiator. I don't beat on the car. Do accelerate briskly and stomp on it for a few seconds, spirited driving if you will. Think I gave all the details
