Wiper arm removal 69 Fury
C Body Bob
Youngsville, NC
Ok, I need to remove the wiper arms from a 69 Fury III to gain access to the wiper linkage transmission. How do they come off?
Lift up, insert nail, push down, walaa
Ok, maybe not that simple.
Look at the arms right at the pivot and you'll see a hole, find a nail or drill bit that will fit snugly in there when the arm is lifted away from the glass.
Lift the arm and pit the pin in the hole, all the way through. Then push back down on the arm, this should release the lock.
You may need to assist the removal a little but do not force it, they should just pop off.
Alan
Alan
Thanks Alan, I saw the tiny hole & figured something needed to be stuck in there....lol
