Would Conversion to Dual Exhaust be Worthwhile?
Henrius
Atlanta
I need to replace the exhaust components of my 1972 Newport with a 400 cubic inch B-block with two barrel. I am musing on converting to dual exhaust. My goal is a small efficiency and power improvement. Would this be worthwhile, or just a waste of time and money?
At a future time, when the engine needs rebuilding, I will probably modify it internally with higher compression ratio and perhaps a different cam. I want to plan for that eventuality.
I think you answered your own question.
Yes, it would be worthwhile. Your engine will breathe better & have a little nicer exhaust tone. I did it to my 383 2 bbl. Fury several years ago & I'm glad I did.
After you get a good dual exhaust with a real nice sound you will swear it's quicker and happier.
So if you go for it what mufflers or sound type would you like? H pipe or no? What style exhaust exits at the back? I found this great fun to ponder as there are so many possibilities for many different tastes!!
Cost/benefit might not be good, but knowing things are better counts for something. Use the 1972 IMPERIAL muffler and match the pipe sizes on it. Same low restriction as the Street Hemi muffler, but C-body quiet and size. When it comes time for the lh side, then duplicate the right side (mirror of the rh side on the lh side) and get the lead pipes built.
I got the '72 Imperial pipe (ball joint connector to muffler), muffler, rear pipe (over the axle), and "resonator replacement" pipe. All from Walter Exhaust, so it fit as it should have. Due to the pitted condition of the balljoint on the y-pipe, I needed to do some additional work there. Easy, painless, and nice. Never did get any baseline figures, but I know it's what I term "sewer pipe single" exhaust. Correct for the vehicle. Due to the rear quarter panel rear area differences, I had to get a muffler shop to bend the very rear pipe upward to clear the trailer hitch. No big deal.
ONE thing I like about the OEM supplier replacement parts is that the pipes and mufflers do tend to last much longer than any muffler shop items I've ever had. Looks right, hangs right and reliably, and lasts. Otherwise, some high heat black or silver paint before installation.
On the '67 Chrysler ONLY, the 383 4bbl had single exhaust. Plymouths and Dodges had duals for the same engine. 325 horsepower ratings for all.
You will have less exhaust restriction with a dual system. Gas mileage will usually go up some, I would expect about .7 to 1 mpg better with the two barrel carb. This is a de-tuned smog motor that is probably struggling to get 10-12 mpg so a 1 mpg increase would be significant. Later on, going to a 4 barrel carb, higher compression pistons and a better cam shaft will also help a lot. If you get the horsepower up with the previous modifications, going to a higher gear ratio will also help if your are looking for more economy. You can also play with the timing and mixture settings with the vehicle as is to see if you can get it to run better. The smog settings are not ideal for either power or economy. Be sure your heat riser is working properly as a stuck heat riser will cause the new exhaust to rot out quickly.
Was the Pope a bouncer in night clubs in South America??
Haha! I did't know that. That's great! I hope he rolled a few out the door.
He got fired because he let in too many "Lepers" as his boss called them. I assume that meant too many lower cast types. If you google "Was the Pope a bouncer in South America?" the Huffington Post story still comes up.
complete resto on my 91 gmc...jacked up 350 alum heads ect ect ....get duals...no problems lm thinkin....spend pile of coin getting duals only to lose my low end torque...spend more coin removeing duals and putting single 3 in back in...truck sounds great and torques back ...learned my lesson...food for thought
A "full on" red line shift of the 700r4 in my 93 roadbastard was 4500 rpm... you could have never kept her up that high for long... I can see where that sort of power curve could lose to duels. WTF... spell check doesn't recognize duals :confused:
I would go with a pair of Flowmaster 40's and duals. I have them on my 78 NYB with a 400 and they sound great!
This finally might be the year for me too. I will eventually pull the engine for a rebuild, but I don't feel like I am there yet. There is good thread out there on mufflers, so I bought my perceived choice, they have been on the shelf now for at least 2 years.
Good luck on your decision, but think of this, I have never heard someone say, "You know I wish I still had that single exhaust" :)
