Kapt
What's the official word on the temperature these engines are supposed to run at? I've heard everything from 180 to 205, but nothing official. Here's why I ask
I have a 60 Dart, 318 Poly three speed automatic. The water pump was replaced last year. Also last year the heads were off and rebuilt. The water jackets do not seem to be plugged. With the cap off and the motor running there is good flow. I had a three row radiator in it and just this week upgraded to a 26 inch core four row Champion aluminum radiator. It has a 180 temp thermostat in it that has been changed a few times now. I'm positive it is a good one. The timing is set at 10 btdc. The car runs 180 down hill and through town. Doesn't seem to want to get hot while at idle or low speed. When I go home and back up the hill, it runs about 190, and hits 200 in my driveway. It did this exact same thing with the three row, it did the exact same thing with the old water pump, and it did it before the heads were rebuilt. It has a mechanical temperature gauge in it make by Equus. I've had several of these in the car because like an idiot, I keep breaking the sender if I have to pull it for some reason. Anyway, there is literally no reason it should heat up. Any ideas? Should I change the thermostat to a 190 where it wants to run at under load maybe?
