Runs and drives
Starts right up every time
315bhp - 383 Chrysler big block with 4bbl carter carb
Ignitor Electronic Ignition conversion (if you know anything about points, this is a nice upgrade)
MSD blaster 2 coil 45,000V
727 3spd auto. Shifts great
Factory power steering fully functional (small leak at reservoir)
New alternator
New air filter
Added tachometer (can easily be removed if desired)
Added water temp gauge (can easily be removed if desired, and use the factory "HOT/COLD" light).
4 matching tires
All matching, correct year hub caps (hard to find)
Headlights and turn signals work
Straight body with minor rust
Brand new custom fit car cover
Trunk load of spare I inherited from previous owner (never needed them and thought about throwing them away)
Class III tow hitch
Retractable antenna and radio still work (if you like listening to AM radio)
All chrome trim accounted for
Similar cars are Chrysler Newport and Imperial
