Lieggi26
please help.
Also looking for emblems for 1965 Chrysler 300
You won't have the trim piece on the front passenger side the trim before the blinker indicator. It's a 90 degree bendThe upper exterior side trim is the same all 65-66 models I reproduce the clips that hold that trim in place. Everything else externally I believe are model and year specific.
However you could put any lower side trim from any model of 1965 or 66, but would not technically be correct.
I have the clips to hold on the lower trim for 1965 New Yorker and 300L 1966 Nyer and 300.
Hope that helps, they were very specific. The front fender would be the same from 2 door to 4mbut then you would need them trim for model number of doors.
Grill and quarter panels both sides. Restoring this carThe “end” pieces are specific to the ‘65 models and is the same across the Newport, 300, 300L, New Yorker and Wagons.
Which emblems are you needing? Quarter panel, grill, interior door panel?
What is ur business info? And how much would you charge?I can’t help you with the grill emblem but can restore your quarter emblem cores.
