Philip Andrews
Polished and clear-coated has so far independently been the answer.Let us know if you figure something out. I bought some from eBay for that reason.
I've been looking at alternatives, believe me. I was just hoping to get this piece of junk to work right, being as I own it already.I hate to be a killjoy, but get an AFB.
They're pretty much bulletproof and simple. Get them setup initially and then forget it.
Hard to tell from the pics but something doesn’t look right with the spring. I wonder why it is at an angle. It’s been a lot of years since I had a look at the inside of one of these so I don’t remember it too well. Have you tried to lower the float levels at all.This carburetor is irksome.
New floats, 5psi fuel pressure and it barfs out of both sides upon fuel delivery.
Gushes with each pump and doesn't hold pressure.
I can't see why, it's all put together correctly.
Phil
It's a funny little beehive shaped conical spring which makes it look like it's at an angle.Hard to tell from the pics but something doesn’t look right with the spring. I wonder why it is at an angle. It’s been a lot of years since I had a look at the inside of one of these so I don’t remember it too well. Have you tried to lower the float levels at all.
You'd think, but so far it's proving elusive.I've used twin Holley 850s on big roots blower motors for boats, and for good reason.
And had a few smaller ones on cars that worked well. If a car had a good working one, I would run it. But I wouldn't buy a new one or repair one for a car.
Carter AVS is my favorite.
A simple Holley float valve shouldn't be too much of a challenge for you.
Don’t leave us hanging what was the problem.Found the problem.
Car runs now
Right now I'm not sure.Are you gonna bring that sweet Pontiac to Cruisin the Coast next week, Phil?
