53ryder
Putting my 1967 Dodge 500 up for sale.
383 cubic inch V-8 with factory 4-barrel carb setup (rated at 325 hp)
Power steering
Power brakes
Automatic transmission with console shifter
Factory radio in dash but doesn't work
After market radio under dash which does work
AC car but does not work
Bought it 2 1/2 years ago off a Dodge dealership in Las Vegas. Have replaced gas tank, sending unit, fuel line from tank to fuel pump, fuel pump. Cleaned out and rebuilt Edelbrock 4 barrel carb, which was on car when I bought it. So fuel system good.
Had friend replace condenser and do the points. Had local brake shop go through and check brake system out in April of '15. Replaced master cylinder and wheel cylinders on both front wheels. So brakes good.
Dash pad is cracked in several places. Southwest car, plenty of heat. Vinyl roof is in good condition, which leads me to think it's been replaced at least once. Foam in seats has dried out as foam crumbs show up on black carpet rather well. Little surface rust in trunk floor. Body fairly clean.
Car starts, runs, drives okay.
Have not put it up on Craigslist yet. Am giving you guys and gals a shot at my car for $4999. Will leave this on FCBO only for a week or two then list it on Craigslist for $5400. Sign in window for neighbors walking by at $5400. Giving FCBO-ers a discount because I feel you all will appreciate car and treat her fairly well. Will consider reasonable offers as well, reasonable. Have clear Washington title.
Glenn
Power steering
Power brakes
Glenn
