For Sale 1967 imperial Le baron 4dr
SGT FURY
Northern California
Feedback: 29 / 0 / 0
I’ve traded this 67 LeBaron for a 68 LeBaron. It’s leaving Monday
for demo derby
I’m keeping motor, trans and radiator.
Has complete auto pilot and a few misc other parts available.
If you see something you might need. Ask SOON.
Be sure to keep that brake booster. It's the dual diaphragm Bendix that everyone is looking for to add discs to slab side cars.
My understanding is that they don't hook up the brakes on derby cars, they just shift from drive to reverse to change direction.
Jeff
Some other parts that may be of interest.
Rear A/C
Glove box trunk release.
Pass pwr seat switch.
Uncracked brown or tan dash pad
Rear defogger.
Nice pair of black California plates.
Sorry,The drivers seat was missing when I got this 67.
The ones I had on 66 went with the
Driver side seat trim for power seat?
car. I saved the switches though.
I do have another 66 that has power seats. I have to dig out of the vines soon.
If I remember right they are painted with a chrome trim.
They look the same?
Will that work or do you need an all aluminum one?
The non-Auto Temp HVAC system should be of interest to someone who wants to convert a non-functioning Auto Temp.
You can get the complete dash out of those with the windshield still in place. It's a bit tight getting to the top bolts, but doable. Certinaly easier than some of the other C bodies.
Jeff
They hook up brakes. The pros use a drive line rear end brake.
This guy wants the front brakes complete I’m getting a complete better 68 LeBaron in return.
Swap in a drum-brake booster instead?
Or make arrangements that you get the booster back?
I will try.!!
Can anybody tell me if master cyl is any different for disc brake cars?
Leave the master connected to the lines and just swap boosters.
You may even be able to use one of the large diameter single diaphragm boosters from a fusey if they aren't going to use the column shift linkage.
I will try.!!
There were only Budd disc brakes on’67/8 & 9 Imperials. No front drums.
