65sporty
I tried to remove the rear window today. But I had a few problems.
All the screw heads of the lower screws on the fiberglass frame are too rusty to unscrew them... I don't have access to the screws from the underside to cut them and I won't damage the fiber glass with a drill...
Any ideas?
I don't know how to remove the center trim piece... This one is tricky! Does anyone know how to remove it?
If you use a drill bit that is the same size as the screw you can just drill the head off and remove your part then use vice grips on the rest of the screw
