SOLD 1970 440 Fury HP Exhaust Manifold RH 2899879 Cast#
1970FuryConv
Richmond, VA
This manifold looks correct, but is an earlier casting #2806900 1967-69. To me it looks exactly the same as what I have seen of 2899879. May be they just changed the casting number for 1970-1971? If that's true, would be interested in early manifold 1967-69 too for right price. I don't want NOS date-matching gold-standard-certified, just a right side 440 HP manifold that will clean up and be painted and be functional. Manifolds with nicks, abrasions, and contusions are welcome to apply. Thanks, Ben
The difference is the heat riser shaft is turned 90 degrees, the counterweight is different, and the bolt clocking is different.
They won’t bolt up to the same pipe.
But they do look the same other than that.
Fantastic answer, thanks!!!!!
So with the bolt clocking different at the outlet flange, would there be a problem for an exhaust shop to make a 2.5" pipe to match?
No problem at all! Just know they take a different pipe so any pre-made pipe will have to be from the same year car and manifold
Understood. So if I ordered from TTI or some place, they'd have to know that to create the right pipe.
