Info...
1970 Dodge Polara
fuel: gas
odometer: 94956
title status: clean
transmission: automatic
1970 Dodge Polara Special
318 V8
Power Steering
Power Disc Brakes
A/C
Good driver. I've put over 3000 miles on the car myself. The 318 V8 is strong with 94,956 (and counting) miles. The engine has a new Cloyes double roller timing set installed to replace the original nylon gear. New water pump. Rubber fuel lines replaced. New fuel pump. New valve covers. New air filter. New hoses. New belts. New points, cap, rotor, wires, plugs. The transmission shifts crisp and functions as it should. Has a deep oil pan. The car handles highway speeds with ease. The car has new dual exhaust with Magnaflow mufflers. New aluminum radiator. Car does not overheat or have any drivability issues. There is a slight noise that seems to be coming from the rear end. Possibly bearings but I have not investigated it.
The front brakes are power discs. The car stops very well! The brakes were gone through and repaired/replaced by the previous owner. All appears to be new or in good shape. Tires are brand new with only 3000 miles on them. The car will come with the original full wheel covers and not the dogdish caps.
The body is very solid. Some minor rust around back glass otherwise there doesn't appear to be any other issues. The car was repainted at some point and is still very presentable. Interior is nice. Front seat would need redone but currently has a cover on it. Back seat is original and in great shape. Door panels excellent. Dash has two cracks but in great shape. Has an aftermarket radio system in it to play your tunes. Trunk has original trunk mat, jack, tire iron, and a spare tire. Pictured is the trunk floor so you can see the condition.
Great car for a police car clone. Great daily driver. Great for a gift. Great to look at. Great for any need.
Clear NC title in my name. I have all the receipts from work done to the car.
$5500.
