monaco75
Mine....
Hey guys,
Thinking it might be time to pass on the torch to a new caretaker. This has been my baby for the last 15 years. Tons of money has been poured into this old girl, along with countless hours of work. I could write a book over this car, however will try to keep it short and sweet. If any questions just ask.
She is a 1975 Monaco. Hours upon hours was spent restoring the body. She is rust free!! She also sports a Movie correct ‘74 grill, with movie dimensions built front push bar. Installed on the push bar is a NOS set of CHP rubber push bumpers. Correct working unity spotlight installed as well. Many hours spent researching/comparing/painting the “decals” on the car. She wears a coat of correct single stage Spinnaker white and “jet” black paint.
Interior is correct tan, with civilian dressed seats. She has a oil/temp gauge and ‘75 up 140 speedo. Aftermarket radio installed with 6x9s in the trunk, as well as dash center speaker still working. New package tray behind the rear seat, and correct horn ring wheel, with added ticket light in headliner. Has correct movie trash across the dash, as well as a siren/PA system installed for some fun.
Engine is a rebuilt 440 with only 4000 or so miles on rebuild. Has a comp cams cam and valve train, melling HV oil pump, eddy 600 carb, HEI dizzy, aluminum radiator, and several other goodies. I had planned on installing EFI, hence the HEI dizzy. However left all the original ignition wiring hidden in place, to be hooked back up if desired. Transmission is a rebuilt 727. Rear end is a correct 9.25 out of a ‘74 Fury Cop car. Has a set of 3.55 gears from a newer model ram.
Suspension has been completely rebuilt including rear leafs, front end, all new steering components, and correct “cop car” torsion bars (out of the same ‘74 Fury mentioned above). KYB shocks all around.
Car was originally a brown 360 civilian car. I have all the paperwork from when the car was bought new! Even the paperwork on the car that was traded in for this one at the dealer. Also included is what is left of the build sheet in a plastic sleeve.
Although I have gone many lengths to restoring her, she is still a 45 year old car, and is not completely perfect. Some items to tend to- Complete installing the A/C system. I bought a sander compressor kit, as well as a complete under hood kit with new condenser. Needs to be completely hooked up still. I have all but 2 of the pieces I believe to finish. Needs a new H block, and H block tubing. New wiper bushings need to be installed, as the old ones have finally failed. Blower motor switch has been replaced once before, however needs it again. Luckily this and the wiper bushings are still easy to get. Rear end has been rebuilt, however I would want to go through it again. Gears have a wine to them at speed.
Car runs and drives great. Stays cool even down here in the FL heat. Again I have tons of pictures, and info if needed. Has a clean tittle.
Asking $25k Or best serious offer. Car does not exchange hands until money is clear.
Hey guys,
