1978 NYB St Regis questions
Fuselage Years
  1. Dana Goetz
    Dana Goetz Member
    55
    14
    Aug 20, 2018
    Owen Sound, ON, Canada
    I'm looking at buying a 78 NYB St. Regis and I have a few questions:
    1. Anyone know the production number for the St Regis package?
    2. The fender tag has a N02 code in the upper right corner. What does that code mean?
    3. Does the 440-4 (E85) engine have a catalytic converter?
    This car is largely unmolested other than a color change. It even has a functioning lean burn system!
  2. PeugFra
    PeugFra Active Member
    467
    120
    Jul 11, 2018
    Italy
    N92 instead of N02 maybe? N92 is what I would expect on a car built for the Canadian market. In 1977 its meaning was "ESA w/o Catalyst" so that answers your third question as well.
    • Thanks! Thanks! x 1
  3. Dana Goetz
    Dana Goetz Member
    55
    14
    Aug 20, 2018
    Thank you. I think you are correct. That corner of the tag is corroded so I want sure of the code.
    It also has the R36 AM/FM cb radio
  4. PeugFra
    467
    120
    Jul 11, 2018
    Italy
    It would be nice to see the tag, if you can manage.
  5. Dana Goetz
    Dana Goetz Member
    55
    14
    Aug 20, 2018
    It was sent to me by the seller on a blind text and I haven't been able to download the picture but I'm working on it
  6. Dana Goetz
    Dana Goetz Member
    55
    14
    Aug 20, 2018
    I can't download the picture but I'll attach the PDF document showing what I've done so far. The last digit of the vin is also unreadable
  7. Mr C
    Mr C Senior Member
    3,595
    1583
    Nov 20, 2012
    All over
    In decades of ownership and playing around with Formals, I've never seen a pre 79 Canadian spec car with a catalytic converter. To my knowledge, cats appeared in Canada in 79. So I'm gonna say "no".
    Plus, N92 means without catalyst which checks out.
  8. CBODY67
    CBODY67 Senior Member
    4,582
    1053
    Mar 27, 2011
    Would the Canadian ESA non-cat cars have a "Non Catalyst" decal on the lh ftont door (near the latch and VIN decal) as the USA cars w/o factory cats did the non-ESA engines (318-2bbl, 360HO, and 400HO) in '76-'77 did?
    Just curious,
  9. PeugFra
    467
    120
    Jul 11, 2018
    Italy
    Wow! An early 1978 NYB for a change, with a Scheduled Production Date of 829! For the real production date, get hold of the door sticker! And clearly Canadian too, with its N92 and the Vehicle Order Number starting with a "C".
    On other NYB tags I have seen, including some for the Canadian market, row 4 is pretty standard and goes:
    M45 P31 P41 N88 G63 M25
    But, if you are really sure about the N in the right-most code, I would say it is N25 "Engine Block Heater". Never seen that on a tag, but this sales code does exist. Codes H23 and N23 as per your PDF are unknown to me.
