BDR529
Well, it's been a while, and the last topic where we discussed this build was in a Big Block into Small Block conversation, so I figured I'd start fresh. I finally got a 440 block that wasn't cracked and had it it bored .030 over and cleaned with new cam bearings installed. My plan is to reuse the connecting rods and crankshaft. I'm moving very slow with projects due to funds but here's what I have so far. I got a set of Keith Black KB237 pistons. I got a Sealed Power piston ring set (E-424K 30) Sealed Power connecting rod bearings (CB 527P) and for the main bearings, Perfect Circle (PMB-2067 P and PMB-2457 P). I have a friend at a machine shop who is going to press out my old pistons for me and I was hoping to start building the motor this weekend and at least get the pistons and crank installed. Here are some questions I have before I get started. First, is there any website or a manual somewhere that gives a good, step-by-step breakdown on how to rebuild a 440? I've never done this before, but I am an aircraft mechanic and tearing it down was easy enough. Also, what bolts need to be replaced? Should I be looking at replacement connecting rod bolts and main bearing bolts? If so, any suggestions on good quality stuff? I'm not looking to go too crazy on this build, I want to keep it on pump gas, 91 is fine. I still need to make a cam selection and get head work done, but for now I'm just trying to get the crank and pistons in since I have what I need at the moment to do that. Any help would be great! Thanks!
