67 300 440 Boiling
Cortez
York, PA
I took the misses out for a quick spin and heard the antifreeze actually boiling. A lil bit came out of overflow hose. I wasn't sure if this is a thermostat or radiator issue. A fella at work said it needs burped????
When cold, remove radiator cap, start engine, let it get up to operating temperature.
Watch air get purged from system.
When purging stops, turn engine off, add coolant.
If you have the radiator that did not come with an overflow bottle, if you fill them to the top they will blow out - every time!
So I let it run until the antifreeze starts to come out? Then let it cool and top off...i leave an inch or two from top free correct?
