Hello gentlemen, I have more electrical questions on my '67 Newport, so I know you guys can help.
1) My oil light on the dash is on full-time, so I know there's an open wire somewhere. What is the location of the oil sender, I can't find it!
2) I have at least one headlight out, but I can't figure out how to swap out a headlamp. Normally there would be a trim ring, a retainer, and out comes the lamp. But this car seems to require the whole damn front grill to be removed just to replace a headlamp!
3) My turn signals will work if I hold the stalk left or right. But the stalk won't stay in position, and nor will it cancel correctly. There was a signal switch in the glove box,which I assume the previous owner replaced, but didn't do it right. Any suggestions? I've done a couple of turn signal mechanisms on the old Buicks (a ***** to get right), but would welcome any advice on this mighty Chrysler's turn signal switch. Any part numbers would be appreciated, in case I need to buy another switch mechanism.
Thanks again to all you guys for your help. My car is coming along great, and I am looking forward to the period of November through April when the weather here gets great and perfect for cruising.
Rich in Tampa
Rich in Tampa
