Allacks
So, I received a fender indicator lens kit for the Fury for Christmas and I went to install it and it turns out its for a Roadrunner. I decided to try it anyways as it said it works for the Bullet Indicators and doesn't fit. The threads are different, which would be fine if it worked as I need to replace both anyways and I could remove the guts and use these. I tried plugging it in the bullet connector(I think thats what it is called) and it didn't work. I tried the good old aluminum foil trick to see if it was a connection problem and nothing. I tried putting everything back together and discovered the front grille indicator and the fender indicator didn't work now. I'm assuming it blew a fuse, but I'm not well versed in the electrical part. Any advice is greatly appreciated!
