When I had my mechanic fix a bunch of things this spring they left the power steering leak issues as an "that's easy enough you should be able to tackle it" thing. Unfortunately as evidenced in my other posts I think they greatly overestimated my abilities since I know how to change oil and brakes. I think i have the last issue finally narrowed down to the PS return valve control body though. It definitely dribbles out from the bottom seam of this thing although not as fast after I removed the inline filter as Big_John suggested (thank you). I'm guessing a bad o-ring but my guesses have been wrong all summer. My questions are as follows:
a) Is this really an easy swap as it appears on pg 19-11 of the service manual - i.e. just two bolts and two O rings that pop back on? No additional adjustments needed to keep another problem from appearing, etc.?
b) I see a number of these listed for A,B,E bodies, but nothing for C or Furies specifically. Does anyone have a link or would this one (below) work anyway? It is a 3/8" hose. I'm amassing a small pile of parts that just don't quite fit since return shipping is ridiculous and the local Auto Zone mainly sells shrugged shoulders for vehicles this old.
Thanks!
1967-74 Mopar ABE-Body Power Steering Pressure Control Valve Body with A 3/8 Dia Return Hose - OER 2537227 - Classic Body Parts
Authentic reproduction of the original power steering pressure control valve return fitting for the steering sector on 1967-74 various Dodge and Plymouth
classicbodyparts.com
Thanks!
