winter project of trying to figure out the messed up wiring.
#1 can't figure out the convertible harness from the switch to the breaker to the motor. it's not the same as what shows in my manual. on the switch end i have a three wire connector,yellow,brown and red. the red is a bullet connector that is folded over and taped to the harness.about half way down the harness is a short tan wire with a female end. other end of the harness has a connector with tan ,brown and yellow. where does the power come from and where does the breaker fit in? am i missing connections somewhere?
#2 the power window harness. the small tan wire , which i assume feeds the relay,according to my manual connects between the main dash harness and the radio. can this be correct? doesn't seem logical to me. perhaps to provide a fused connection? on the body end of the harness is a red triple bullet connector that i can't find in the manual. what is this for? any ideas appreciated
