WANTED A/C line needed
bluefury361
Alabama Gulf Coast
Feedback: 14 / 0 / 0
I need the A/C line that connects the receiver dryer to the expansion valve on a 1969/70/71 C body with manual A/C. It's the last link to the Admirals A/C system.
I thought I was good until I noticed the "kink" in the line at the forward fitting. Mine might work but is very restricted.... need to replace.
Used on all 69/70/71's and perhaps later models as well.
Thanks, Will.
Friend Will. If you can not find a place to copy that line you might try CTC AUTO RANCH in Denton, Tx. They show several dozen C-Bodys partz carz of those 3 yearz in their inventory and Those folkz in Tejas know all about A/C in their ridez from way back. 940-482-3007 G L with the chase , Jer
I might have one.
I was able to do some bodywork on a hose with similar damage. I used a drift on the inside till I could get a #3 Philip screwdriver in, the drift hit the curve in the tube before it fit the diameter.
Alan
Sorry Will, no luck. If nobody has one I'll try a salvage yard out West, I need a few things myself.
Here is another if that will not work.
This is off a 69 Polara with a 383
Alan
Okay mine is more 90/90 zig zag at the drier not like Alan's
The one on my CHP car (a 69 HP 440 Polara) was 90/90 also not like the 45/45 one I previously posted as available.
An original line that have been cleaned up, the one I have available should clean up this nice (vinegar and steel wool).
Alan
I saw lines like this one on the 68's I found in a salvage yard. I need the first one you posted Alan.
I need one of these for my 71' Fury if anyone has one available. ..
Thanks
