A little bit of help with identification..
'69FuryIIIConvertible
Fixer of junk
Newcastle, Ontario, Canada
Need some help from you kind, wonderful folks with some identification of some parts that were among the big pile of stuff I hauled home.
1. Prestolite direct drive starter, should have 10 tooth or is it 12 tooth. Works with 172 tooth 11 Hemi flywheel. Also works with old slant sixes
2.pinion snubbers top for a 8 3/4 bottom for a 7 1/4 rear
3.extended pulley for a truck application (best guess)
4.slant six trans torque converter cover
5. Early b body trans mount? Xxx truck mount of some sort.
6. Power steering bracket.
7. ? Maybe early b body broken motor mounts... Really guessing
8.BB point dist. (B or RB ?)
9. Back side of above distributor.
Starter is early slant 6 60-63 maybe 64 as well. Inspection cover is /6.
Alt bracket looks like poly 318 . Motor mounts also appear to be poly. Trans mount looks like 65 C. Distributor is 68 383 2bbl auto. Most important is the VIN off that Hemi !
The distributor is from ‘68 B or C body 383 2 bbl with Auto trans.
I have a couple of the extended pulleys like this one. They both were on add-on a/c systems.
You guy's rock, busting out answers, I was looking at the pic's with out a clue except for the dist.
