Samplingman
I'll be pulling the 440 out of my 300 vert tomorrow, and realized the last time I did something like this was over 30 years ago, any advice would be appreciated. First, where is the best place to bolt up the chains from the hoist? Should I remove the carb, alternator, fan, etc, first? Should I pull the trans with the engine, or do them separate? Speaking of the trans, I've taken out the mounting bolt, but do I need to remove the cross member as well? Should I have the front elevated to make more clearance for the trans? Yes, a lot newbie questions, but I'd rather ask and get opinions then fool around with 1000 lbs of metal swinging through the air.
