Reviving this thread in the hopes of comparing some notes while trying to also diagnose a hot start problem I am having with my FiTech.
On warm days (90F +), my engine usually won’t start after short stop... say 30 minutes or less. It fires right up at a cold start and runs great the entire time. But after a short stop, it acts like it is flooded. The control panel will turn on for a brief moment, but then goes blank. Try again and just crank with no start. My solution, pop the hood, let it cool down for a long while, then check the control panel. If it stays lit, it fire right up.
the feeling that it is flooded got me doing some research and I found some information about the cranking fuel Prime shot at various temperatures. Apparently mine was kept at the factory settings when it was installed: 259 prime shot, 0.0 at 20F, 0.0 at 65F and 0.0 at 170F. Soooooo, I figured I’d lower the prime shots at the various temperatures. I put in0.0 at 20F, -20.0 at 65F and -50.0 at 170F. Went for a drive, got it warmed up stopped for a bit, same problem.
If anyone else out there has a FiTech, I’d love to know what your cranking fuel prime shots are set at.
